deep blue
deep blue
deep blue
I delete deep blue from the setting by fault and i want it back, i renamed CfgUsr folder and i deleted him and it doesn't work, i reinstall and it doesn't work neider, please i need help.
Refaat
Hi @mouade.houmada
Which is version number of Robot?
Refaat
Refaat
Hi @mouade.houmada
Try to replace the attached with the exist one .
C:\Users\Username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 2017\CfgUsr
Refaat
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I just wanted to check if the folder sent by @Refaat helped you to restore this color scheme? in fact it should be enough to rename this folder to e.g. 1_CfgUsr on your machine. If this issue has been solved would you mind marking Refaat answer as the solution so that it is easier to find by others? Thank you.
Artur Kosakowski
I delete deep blue from the setting by fault and i want it back. I use robot 2020
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Close Robot 2020
Rename
C:\Users\%user -login%\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 2020\CfgUsr
to
C:\Users\%user -login%\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 2020\CfgUsr-old
Restart Robot
Krzysztof Wasik
