C# (API) Load Combinations null value
Benjamin.Ainsworth
Benjamin.Ainsworth
I am busy trying to create a load combination in Robot using C# API and visual studio.  My code can be seen below:
Structure = Robot.Project.Structure;
CaseCollection = new RobotCaseCollection();
RobotLoadCombination = new RobotCaseCombination();
CaseCollection = Structure.Cases.GetAll();
int loadCombinationNumber = Structure.Cases.FreeNumber;
int loadCaseFactorNumber;
//ULS or SLS condition
if (loadCombination.Condition == "ULS")
RobotLoadCombination = Structure.Cases.CreateCombination(loadCombinationNumber, loadCombination.Designation, IRobotCombinationType.I_CBT_ULS, IRobotCaseNature.I_CN_SEISMIC, IRobotCaseAnalizeType.I_CAT_COMB_CODE);
else
{ //SLS
RobotLoadCombination = Structure.Cases.CreateCombination(loadCombinationNumber, loadCombination.Designation, IRobotCombinationType.I_CBT_SLS, IRobotCaseNature.I_CN_SEISMIC, IRobotCaseAnalizeType.I_CAT_COMB_CODE);
//Assign Load Case Factors to Load combination
foreach (LoadCaseFactor loadCaseFactor in loadCaseFactors)
loadCaseFactorNumber = LoadCaseExist(CaseCollection, loadCaseFactor.LoadCaseName); //This is a function to retrieve the exisiting case number
RobotLoadCombination.CaseFactors.New(loadCaseFactorNumber, loadCaseFactor.Factor); //The error occurs here.
The above error is showing because RobotLoadCombination is null, as can be seen here:
But it only becomes null after the CreateCombination rule has run.
I have exactly the same line of code in VBA and it runs fine. Am I missing something.
Stephane.kapetanovic
hi @Benjamin.Ainsworth
Private Sub CreateCombination()
  Dim RobApp As RobotApplication
  Set RobApp = New RobotApplication
  Dim Cases As RobotCaseServer, Comb As IRobotCaseCombination, CaseFactors As RobotCaseFactorMngr
  Set Cases = RobApp.Project.Structure.Cases
  CmbNbr = Cases.FreeNumber
  Set Comb = Cases.CreateCombination(CmbNbr, "COMB" & CmbNbr & " [ULS] 1*1.35 + 2*1.5", I_CBT_ULS, I_CN_EXPLOATATION, I_CAT_COMB)
  Set CaseFactors = Comb.CaseFactors
  With CaseFactors
    .New 1, 1.35
    .New 2, 1.5:
  End With
  Set RobApp = Nothing
End Sub
static void CreateCombination()
    RobotApplication RobApp = new RobotApplication();
    RobotCaseServer Cases = RobApp.Project.Structure.Cases;
    int CmbNbr = Cases.FreeNumber;
    string Title = $"COMB{CmbNbr} [ULS] 1*1.35 + 2*1.5";
    IRobotCaseCombination Comb = Cases.CreateCombination(CmbNbr, Title, IRobotCombinationType.I_CBT_ULS,
        IRobotCaseNature.I_CN_EXPLOATATION,
        IRobotCaseAnalizeType.I_CAT_COMB);
    RobotCaseFactorMngr CaseFactors = Comb.CaseFactors;
    CaseFactors.New(1, 1.35);
    CaseFactors.New(2, 1.5);
    RobApp = null;
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Benjamin.Ainsworth
Thanks so much, it is working now.
I compared our code and I saw that the only difference was that I had this:
 But it should have been :
 Thanks again.
see also:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-generate-code-combinations/m-p/54...
