Buckling critical coefficient changes if run with another separate P-Delta analysis
Be_S_
Be_S_
I have a tall, braced steel structure model set up in Robot structure. When I run the model with buckling case only, the result of the critical coefficient differs from when I run it together with another P-delta analysis case at the same time.
Note that I defined two complete separate buckling and p-delta analysis cases. Only running them at the same run changes the result of the buckling case.
Anyone had the same issue or knows why this happens?
Rafacascudo
Zip and attach the model , if possible
Rafael Medeiros
