Buckling Coefficient
can someone explain what red squared symbols represent?
What I need are buckling length coefficients for column 1 and 2 while all nodes and supports are fixed.
How should I set values in "Adjoining Members Parameters" to achieve this!?
Regards!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The option you indicated stands for the connection type on the other side of the beam. For the fixed you should select the middle one.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
@Artur.Kosakowski
Thank you,....
I suppose the first one is pinned, second one stands for fixed node (my case), but what does the third symbol represent? Can you make an example for the third symbol?
Regards!
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Please check this article.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
