I have a simple beam and I am applying some knocking forces and measure the acceleration by sensors.
I am trying to model this beam and loads to get the deformation can happen.
My question is: What is the best way to define the loads, is it good to define them as body forces?
because of my measurements units from the accelerometers (g or m/sec^2).
Any advice will be appreciated
Solved by mustafahesenow. Go to Solution.
@mustafahesenow Thank you. Actually, you are right, These type of forces are changing with the time so it's better to use time history analysis.
I watched some video about it and I ran my model but unfortunately, the results are (zero). Maybe I miss something
