Bending moment using clear span
Message 1 of 22
hello,
why does robot calculate bending moment in Rc elements design using middle to middle span instead of clear span.
For example, if I am designing a simply supported beam with 5m clear span supported by 2 columns 1m width each, Robot will take L=6m while calculating the maximum bending moment using the formula WL2/8. However, L should be equal to the clear span Ln= 5m.
Replies (21)
Message 21 of 22
Thank you @Artur.Kosakowski
Message 22 of 22
kitlnwza
Observer
Observer
How to do it. why my bending in continuous beam is same ft_111's model
