Bending moment results of strap beam
MUHANNAD.ABU_ABDO
Message 1 of 8
MUHANNAD.ABU_ABDO
Hello, during analyzing & design strap beam connected two isolated footing i found the following results as in the pics below
Max negative moment obtained from robot 77.92 t.m But the -ve moment obtained from hand calcs is 92.9 t.m
Max positive moment obtained from robot 41.4 t.m But the +ve moment obtained from hand calcs is 48.07 t.m
Why there are discrepancies in results ?
Model file attached
Thanks in advance
Muhannad M.Abu Abdo
Structural Design Engineer
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @MUHANNAD.ABU_ABDO
What is the static scheme you assumed for your hand calculations? What is the span length between the supports (was the real size of the foundation considered) ?
Artur Kosakowski
Message 3 of 8
MUHANNAD.ABU_ABDO
I assumed the soil pressure is uniform stress under the footing and get the desired dimensions , strap beam not considered to exposed to soil pressure . all the assumptions considered in the model & hand calcs are the same
Muhannad M.Abu Abdo
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
OK. Let me ask the question in the different way. Have you included the stiffness of the panels in your hand calculations or are you directly comparing the results for a beam on elastic soil with your more accurate model?
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 5 of 8
MUHANNAD.ABU_ABDO
No i didn't include the panels stiffens in the hand calcs cuz this's gonna be complex little bit , strap beam will just carry the overturning moment , and the two footings are exposed to soil pressure ! in this case i couldn't assume the bar is elastic on soil ! is that wrong ?
do u mean when i want to compare between hand calcs and robot i have to reduce the panels stiffens cuz the manual method assume all the overturning moment will directly transferred to the strap beam ! but this'not the exact behavior and the panels will take some moments ?
Muhannad M.Abu Abdo
Message 6 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
IMHO it is exactly what you should do as proven by the test model shown on the picture I attached to my previous post.
Artur Kosakowski
Message 7 of 8
MUHANNAD.ABU_ABDO
Thanks for your clarifications , Last question soil of elastic beam  should defined as t/m2 or t/m divided on the beam length ?
Muhannad M.Abu Abdo
Message 8 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Force that cause a beam of a unit length with given width (e.g. 0.5 m) to move (downwards) by unit of displacement
(t / m * m * m) * 0.5m [t/m2]
Artur Kosakowski
