Passing loads from steel columns to foundation r.c. design
Hello all,
I am having difficulty with the workflow for passing loads from a steel frame design of a portal frame to the R.C. module for design of the foundations.
I have selected the supports and then using the "Provided Reinforcement of RC Elements" to push them through to the R.C Design module. I am then selecting the manual load combinations and the correct number of the foundations appears to be generated. The loading information from the steel frame (the reaction forces at the supports) doesn't seem to translate through though which is essential to the design. What am I missing?
Ultimately I want to generate simple square foundations without any piers and simple fabric reinforcement.
Thanks.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach your model?
Artur Kosakowski
Hi Artur,
Thanks for the prompt reply. Model attached.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try RC Elements > Load Table commands:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Hi Artur,
Thanks for this, I see the loading for all of the individual load cases. Is there a way to automatically select the most onerous load case and design the foundation to suit? Or do I have to manually go through them all and then manually input them into this dialogue?
Also, the foundation type by default has a pier, what's the best way to avoid this? I simply want a square/rectangular foundation with a bolted connection from the steel column. At this stage the baseplate size to the column is unknown with the design responsibility falling to third party.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
For the group of foundations the design is done for the loads from all combinations from each of the node which belong to this group one by one. The final foundation size is such that it is OK for all of them. If you know which one is the worst just import only this one from a model.
You need to set it each time as there is no option to save the default foundation geometry.
Artur Kosakowski
