Hello
Can you help me in this simple model: beam with reservation + a message d'error
Hello
For the no loads defined error you simply have to define any.
For the calculation error (I tested self weight load) you need to reduce the size of the opening. I changed its height from 20 cm to 15 cm and the beam was designed with no errors.
