Continuous Beam design
Message 1 of 41
how do i model a continouis beam with a roller support at the mid span. i need the beam to be continous.
also how do i model a joint to have a semi rigid/pinned support. with a different stiffness.
thanks
Replies (40)
Message 2 of 41
Artur.Kosakowski
Autodesk Support
Autodesk Support
It should be enough to  define a node with the UZ blocked at the point where the support is located.
Use the elastic (tab) support definition
Artur Kosakowski
Message 3 of 41
i get insability how can i change this
in all directions how do i change this
do i leave Ux and Ry unticked ?
Message 4 of 41
Artur.Kosakowski
Autodesk Support
Autodesk Support
Attach the model please.
Artur Kosakowski
Message 5 of 41
heres the model
i need to model semi rigid/pinned supoports at node 3 and 4
and a contiouous beam from 1-3
with a roller at the point show
Message 6 of 41
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm not sure if I understand this description correctly. Could you make a sketch of the model and indicate which d.o.fs you want to block, have elastic, release in particular nodes please?
Artur Kosakowski
Message 7 of 41
the structure is a cantilever extention. from nodes 1 to node 3 is a continuous beam with a roller support at location node 2. i want to make it cantilever but i am struggling !
i also want to make node 3 and 4 semi rigid/fixed .
i have attached the poster for my structural project if this helps
Message 8 of 41
jo
Message 9 of 41
Artur.Kosakowski
Autodesk Support
Autodesk Support
The modified model  as on the picture you attached
Artur Kosakowski
Message 10 of 41
Artur.Kosakowski
Autodesk Support
Autodesk Support
 And the model that (I hope) matches this description
Artur Kosakowski
Message 11 of 41
thank u this is very helpfull! howvere i keep getting instability at node 2 ( between the contiousous beam ) ! do i have to model the releases or is it just on the supports! or do i have to change flanges ? im usure ! appoligies i am new to robot and taking a while to get the hang of things.
Message 12 of 41
Artur.Kosakowski
Autodesk Support
Autodesk Support
In the model you attached you defined the compatible nodes in such a way that node 2 is not connected with any element of the model so you may delete this definition to get rid of the instability error.
Artur Kosakowski
Message 13 of 41
i have tried this everal times it keeps coming up with instability i have joined the two beams with the -fxf and kept the roller support unjoined i dont know what to do !?
Message 14 of 41
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 15 of 41
took me a while ! but i got there thank u for the great help ! structure seems to be working all well thank you
Message 16 of 41
if i now wanted to model a fixed  spring at the top left hand node ! how would i do so ! i have a picture attrached of what i think it would look like !? wetrher it is a roller or pinned or fixed im not sure !
Message 17 of 41
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 18 of 41
perfect thanks i take it there is more opptions in urs as its 3D ?! and what sort of value could i give for this ? is 12345 okay im not sure what to use ?
Message 19 of 41
Artur.Kosakowski
Autodesk Support
Autodesk Support
12345 stands for the stiffness of the spring and this is the value you should know. I'm sorry but I don't understand the other part of your question.
Artur Kosakowski
Message 20 of 41
thanks i understand now !
