beam with reservation
colastanarobo
colastanarobo
HelloSmiley Happy
Can you help me in this simple model: beam with reservation + a message d'error
Artur.Kosakowski
Autodesk Support
Autodesk Support
For the no loads defined error you simply have to define any.
For the calculation error (I tested self weight load) you need to reduce the size of the opening. I changed its height from 20 cm to 15 cm and the beam was designed with no errors.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
colastanarobo
nice
thank you
