Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
saclovitzky
397 Views, 3 Replies
Beam model
I've modelled a 400x600mm dp RC Beam(5m long), then modelled it again as a wall(same dimension/span).
I am trying to find out, whether, when it is modelled as wall(RC Beam), I can have the same moment result(typ beam analysis) against "reduced result for panel" when the beam is modelled as a wall.
Looking at the result;
Typ Beam model    ; My  = 45.93 kN.m
Wall model              ; NRx  = 97 kN (where is the moment?)
Pls. see attached file and screenshot
Any ideas will be greatly appreciated.
3 REPLIES 3
Rafacascudo
in reply to: saclovitzky
To compare you have to model equivalent conditions. FE model should have supports on panel center line nodes. On the bottom nodes you generate horizontal reactions as both supports have restricted Ux translation.
Setting blocked Ux supports on the center line nodes or keeping them at the bottom but releasing Ux direction on one of them , you will have similar results on both models. On reduced results table , MRz is the in-plane moment
Of course , precision is improved if you refine the mesh
Rafael Medeiros
saclovitzky
in reply to: Rafacascudo
Thanks Rafacascudo, you're a legend.
Rafacascudo
additionally, you can also have similar results if you need to keep the Ux supports blocked at the beam´s base using offsets or rigid links for the bar model and rigid links on the edge nodes of the FE model.
Rafael Medeiros
