Beam check/ Lateral restrain
- Mute
- Permalink
- Report
I wanted to ask if there is a simple way to laterally restrain beams. At the moment I just applied restrains at every 0.05L however I am not sure whether that is the right procedure.
In the attached model, I am only interested in the lower level portal frame. I performed a simple check to see whether the load is being distributed correctly. I applied a permanent load 2kN/m2 on the first floor slab and calculated a deflection for the middle beam (10) to be 16.5mm (5x(2x4.3)x7160^4)/(384x210000x8500x10^4). I understand it's two point loads rather than UDL however the difference is so large. Can you please advise why can this be?
Thank you.
