Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
ARSA2016 RC plates deflection problem
2 REPLIES 2
269 Views, 2 Replies
Have anyone noticed that there is no any more possible to calculate deflections (equivalent stiffness or with stiffness update) for chosen combination eg. SLS. The program only shows load cases. Is there any option in ARSA 2016 to run calculations for combinations??? See attached files.
2 REPLIES 2
Rafal.Gaweda
Update your Robot with SP1
Rafal Gaweda
and then install HF2
http://forums.autodesk.com/t5/robot-structural-analysis/hotfix-2-for-autodesk-robot-structural-analy...
Artur Kosakowski
