Have anyone noticed that there is no any more possible to calculate deflections (equivalent stiffness or with stiffness update) for chosen combination eg. SLS. The program only shows load cases. Is there any option in ARSA 2016 to run calculations for combinations??? See attached files.
Solved by Artur.Kosakowski. Go to Solution.
and then install HF2
