Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
ARS2016 – Desktop Settings
6 REPLIES 6
Refaat
724 Views, 6 Replies
Dear Colleagues
I am trying to use the defaults desktop settings (ARS2016) as shown in the attached video. But I have gotten corrupted settings. Only (OCEAN & BASIA) are working and all of the other settings stuck on them.
Knowing that I have installed SP1(ARS2016) .
Also, I have (ARS2015) on the same computer and it is working perfectly.
Pls , May I know , what is the reason of that ?
Thanks in advance
Refaat
6 REPLIES 6
Try to play with video acceleration parameters, in the robot preferences.
Cheers
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Artur.Kosakowski
in reply to: Refaat
Try to rename your CfgUsr folder for Robot 2016.
Artur Kosakowski
Refaat
in reply to: Artur.Kosakowski
Dear Artur
I have tried both ideas (play with display acceleration & rename Cfg. File) on another computer (workstation). Unfortunately, still doesn’t work.
Kindly , take a look to the attachments .
https://www.mediafire.com/?53ekj5h6su8p2et
Any other help, please.
Refaat
Artur.Kosakowski
in reply to: Refaat
I'm sorry I should have given you the full path to this folder but as it was referred to on this forum and indicated in the last Robot webinar I assumed it is already well known to anybody Smiley Sad
CfgUsr is located in C:\Users\user_name\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 2016 directory. Rename it to e.g. 1_CfgUsr and rename Cfg folder you changed name to CfgUsr (visible on the rename movie) back to Cfg.
Artur Kosakowski
Refaat
Dear Artur
Thanks a lot . It is fine now  Smiley Happy
Refaat
I played with the desktop settings and it has changed the background and model colours. I think i depressed the standard button and it changed the colour settings (see attached). I normally use the deep blue setting.
Can you advise how i can get the default deep blue setting back?
See attached files.
Thank you
Eric
