Arc Beam
Arc Beam
Message 1 of 20
Arc Beam
Dear All,
I would design an arc beam, but I do not know how to merge 9 bars in one. I have tried the Rafal.Gaweda addin ( merging bars) but it does not work for not aligned bars.
Could you suggest me something please?
Replies (19)
Message 2 of 20
Hello
why do you want to merge then.
Even not you can do the calculation you want as if you only have one single curved beam.
I dont think you can do it...You would have only two nodes...
Message 3 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Please check this topic:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/rc-spiral-car-park-ramp/m-p/7380084/highlight/true#M57813
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 4 of 20
Muhammed.OPERA
Hi @Anonymous
I may also have another thing you can do:
Model the stair or the curved thing that is supported on the beam then replace the beam by a linear hinged support.
Then you can take the integral value (longitudinal force / Unit length) of the linear support reactions in all directions and model the beam as line with those reactions as inverted loads upon the beam.
That way you can use the RC element design Module to design that beam with the loads.
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Message 5 of 20
@Anonymous I want to merge them because I would design it as it supposed to be: just one beam.
it is going to be hard for me design 9 small beams. Might @Artur.Kosakowski help show me how I could manage for calculating those beams! ( I'll appreciate a lot!).
@Muhammed.OPERA can you post a video how I can do that please?
If load are missed, add 200 daN/m2 in each panel!
Message 6 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
To calculate required reinforcement you can try this approach but distribution of reinforcement bars or calculations of cracked deflection will not be possible.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 7 of 20
I think is more convenient get the nodes aligned, in order to have a "normal" beam. What do you think @Artur.Kosakowski?
Message 8 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'd say this depends on the actual bend radius of the beam and additional effects it creates (torsion).
Artur Kosakowski
Message 9 of 20
@Artur.Kosakowski in order to make it easier what do you think if I create a beam linked in the extreme nodes, after that moving all the bottom nodes to the "new" aligned beam?
In pink the new beam
In green the nodes moved
Message 10 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Either will do. I can't see too much of the difference in the required actions.
Artur Kosakowski
Message 11 of 20
Because in this way I can see distribution of reinforcement. In your post N. 6 it is not possible!
IMHO I would (when is possible) work with aligned bars!
@Artur.Kosakowski which method you can suggest to me?
Message 12 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
It seems that I might have misunderstood your question. Do you ask me which method (required reinforcement for curved beam modeled as a chain of smaller bars vs. provided reinforcement for a straight beam) is better or which way of creating a straight beam with adjusted panels is better?
Artur Kosakowski
Message 13 of 20
First one @Artur.Kosakowski
"which method (required reinforcement for curved beam modeled as a chain of smaller bars vs. provided reinforcement for a straight beam) is better"
Message 14 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
If you want to have reinforcement bar distribution generated (and torsion is negligible) you may decide to 'replace' the curved beam with the straight one.
Artur Kosakowski
Message 15 of 20
but what about if I put a panel below those nodes?
Message 16 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
I'm not sure if I understand what you mean. Is it that you want to connect panels with this straight beam?
Artur Kosakowski
Message 17 of 20
now I'm wondering if is possible to link instead of using a beam, to use a panel or a floor, since the nodes on the bottom are not aligned
Message 18 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You may consider moving the panel contour's corners to the positions along the defined straight bars.
Artur Kosakowski
Message 19 of 20
thank you so much @Artur.Kosakowski
Can I ask you last thing? can you post a video about how do you achieve that please?
Message 20 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
First I created a straight beam between the end nodes of the arch beam. Then created the same number of nodes along its length as the number of nodes for the arch beam pieces and deleted the arch beam. Finally I moved the corners of the panel contours to the nodes I created along the straight beam by  clicking two times on the panel corner and dragging it to a new location.
Artur Kosakowski
