(API) Take forces with characteristic points
eng_leandromartins
Message 1 of 29
eng_leandromartins
Hello everyone,
I searched other topics but every time I found something similar the topic was closed because it was too old.
I would like to use API to automatically transfer the results in the image below to Excel.
I thank you in advance!
Replies (28)
Message 21 of 29
HoshangMustafa
@Stephane.kapetanovic
you stated:
hi @eng_leandromartins
sometimes, column indexes are provided on the forum; other times, you may need to search for them yourself or develop a bot.
If you can't find them, it's best to ask here.
Best Regards
What do you mean by this phrase "bot"?
Best regards
Message 22 of 29
Hi @HoshangMustafa
I still don't see how I can help you.
'bot' means a program that performs a search for you. In this case, look up the column indexes to make a dictionary.
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 23 of 29
eng_leandromartins
Hi @Stephane.kapetanovic
Do you know why when I put "Combinations", where indicated it doesn't select any combination?
Message 24 of 29
if you use a working and editing language in Brazilian, you can choose ‘TOD’ instead of ‘all’.
Key (Integer) Part 1 Part 2 Part 3 Country
1 ALL to By United States
33 TOU A P France
34 TOD A CA España (Spain)
39 TUT a P Italia (Italy)
40 ALL la By Romania (Romania)
44 ALL to By Great Britain
48 WSZ do K Polska (Poland)
49 ALL bis S Deutschland (Germany)
55 TOD para Por Brasil (Brazil)
70 все до Через Russia
81 ALL to By Japan
86 全部 BY China
Best Regards
Message 25 of 29
eng_leandromartins
Sorry, @Stephane.kapetanovic I wasn't very clear.
I want to select Combinations only. When I put "Combinations", it doesn't select any Combinations.
I'm working with the English language.
Message 26 of 29
not knowing what type of combinations, you will have to adapt the code.
Sub SelectionAllCombinationsAPI()
  Dim RobApp As RobotApplication, Selections As RobotSelectionFactory
  Set RobApp = New RobotApplication
  Set Selections = RobApp.Project.Structure.Selections
  For Each Typ In Array(I_PS_CASE_COMBINATIONS, I_PS_CASE_CODE_COMBINATIONS)
    Txt = Txt & Selections.CreatePredefined(Typ).ToText & " "
  Next
  Debug.Print Trim(Txt)
  Set RobApp = Nothing
End Sub
Best Regards
Message 27 of 29
eng_leandromartins
Thank you,
It worked perfectly.
I'll leave the code in C# below for those interested.
IRobotApplication robotApp = new RobotApplication();
RobotSelectionFactory selections = robotApp.Project.Structure.Selections;
string txt = String.Empty;
foreach (var typ in new object[] {IRobotPredefinedSelection.I_PS_CASE_COMBINATIONS})
    txt += selections.CreatePredefined((IRobotPredefinedSelection)typ).ToText() + " ";
robotTable.Select(IRobotSelectionType.I_ST_BAR, "all");
robotTable.Select(IRobotSelectionType.I_ST_CASE, txt.Trim());
Message 28 of 29
    selections.CreatePredefined(IRobotPredefinedSelection.I_PS_CASE_COMBINATIONS).ToText());
Message 29 of 29
a simpler solution to find column indexes for your programs.
Header Explorer - Stop searching for where to find column indexes in Robot Structural Analysis
