Table columns API
Table columns API
cherifmetarfi
Message 1 of 8
Table columns API
cherifmetarfi
i have this part of code
IRobotApplication robot = new RobotApplicationClass();
string text = Path.GetTempPath() + "\\temp.csv";
RobotTable robotTable = robot.Project.ViewMngr.CreateTable(IRobotTableType.I_TT_STOREYS, IRobotTableDataType.I_TDT_DEFAULT);
robotTable.Select(IRobotSelectionType.I_ST_CASE, "6");
 i want to add height column but i can't achieve that using  robotTable.AddColumn(i);
Replies (7)
Message 2 of 8
Stephane.kapetanovic
hi @cherifmetarfi
Sub GetStoreyHeight()
  Dim RobApp As RobotApplication
  Set RobApp = New RobotApplication
  Dim Storeys As RobotStoreyMngr
  Set Storeys = RobApp.Project.Structure.Storeys
  If StoreysCnt <> 0 Then
    Dim Storey As RobotStorey
    For i = 1 To Storeys.Count
      Set Storey = Storeys.Get(i)
      StoreyName = Storey.Name
      Height = Storey.Height
      Debug.Print StoreyName, Height
    Next i
End Sub
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 3 of 8
cherifmetarfi
thank you for response, i have to achieve that but i want to do it in table (RobotTable) there are other cases that's why i want to know how addColumn works
Message 4 of 8
try 1809
Message 5 of 8
cherifmetarfi
thank you so much it works but how i can column index, i have simillar work with other table types (haev i to try randomly or there is a list of columns names )
Message 6 of 8
Sometimes, column indexes are provided on the forum; other times, you may need to search for them yourself or create a bot. It's best to ask here if you can't find them.
Message 7 of 8
cherifmetarfi
thank you for you help
Message 8 of 8
a simpler solution to find column indexes for your programs.
Header Explorer - Stop searching for where to find column indexes in Robot Structural Analysis
