(API) Take forces with characteristic points
eng_leandromartins
Message 1 of 29
eng_leandromartins
Hello everyone,
I searched other topics but every time I found something similar the topic was closed because it was too old.
I would like to use API to automatically transfer the results in the image below to Excel.
I thank you in advance!
Replies (28)
Message 2 of 29
Stephane.kapetanovic
hi @eng_leandromartins
this code saves the current table in a ‘TXT Files’ folder under your project directory and opens it in Excel.
Sub GetTable()
  Dim RobApp As New RobotApplication
  If RobApp.Visible <> -1 Or RobApp.Project.IsActive <> -1 Then Exit Sub
  Dim Table As RobotTable: Set Table = RobApp.Project.ViewMngr.GetTable(1).Get(1)
  Dim workPath As String:   workPath = Left(RobApp.Project.FileName, InStrRev(RobApp.Project.FileName, "\")) & "TXT Files"
  With CreateObject("Scripting.FileSystemObject")
    If Not .FolderExists(workPath) Then .CreateFolder workPath
  End With
  On Error Resume Next
    Workbooks(Dir(RobApp.Project.FileName)).Close False
  On Error GoTo 0
  Dim EntireFileName As String: EntireFileName = workPath & "\TableTxt.txt"
  Table.Printable.SaveToFile EntireFileName, I_OFF_TEXT
  Workbooks.OpenText EntireFileName, , , xlDelimited, , , , , , , True
  Set RobApp = Nothing
End Sub
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 3 of 29
to create the table and modify the columns
Set Table = RobApp.Project.ViewMngr.CreateTable(I_TT_FORCES, I_TDT_DEFAULT)
With Table
  .Select I_ST_BAR, "1to4 9to19"
  .Select I_ST_CASE, "1 2"
  For Each ColumnNumber In Array(269, 270, 282, 271, 24, 149, 480)
    .AddColumn ColumnNumber
  Next
End With
see the updated file (GetCurrentTable.xls) in the following replies
Message 4 of 29
eng_leandromartins
Thank's @Stephane.kapetanovic
Is there any way to set the characteristic point via API?
Message 5 of 29
Hi @eng_leandromartins
I've never tried it. Two options are available where applicable, but non-synchronous multiple points between bars, as shown in your image, are not implemented.
  With RobApp.Project.ViewMngr.CreateTable(I_TT_FORCES, I_TDT_DEFAULT)
    With .Configuration
      ' first option
      .SetValue I_TCV_POSITION_OF_DIVISION_POINT, 0.25
      ' second option
      .SetValue I_TCV_NUMBER_OF_DIVISION_POINTS, 5
    End With
  End With
For my own use, I select the load cases, bars, nodes, and relative or absolute positions, and my program takes care of the rest.
Best Regards
Message 6 of 29
eng_leandromartins
Thank's @Stephane.kapetanovic ,
Is there any way to set this flags via API?
Message 7 of 29
You can do this in Excel.
Message 8 of 29
eng_leandromartins
Thank's @Stephane.kapetanovic.
Another question. How do I find out which index each column I want to appear?
I looked in the documentation, but I couldn't find anything!
Message 9 of 29
sometimes, column indexes are provided on the forum; other times, you may need to search for them yourself or develop a bot.
If you can't find them, it's best to ask here.
Best Regards
Message 10 of 29
eng_leandromartins
Thanks for the answers @Stephane.kapetanovic
I honestly have no idea how to create a bot to get the column indexes.
I'll ask on the forum. Do you happen to know the index of the Name of member column?
Message 11 of 29
750
Message 12 of 29
HoshangMustafa
Hi @Stephane.kapetanovic
can you elaborate more on this line of code, especially the AddColumn function:
 From The Robot API pdf: The function adds to a table a new column that will present data of the
indicated type .
Message 13 of 29
hi @HoshangMustafa
each element of the array corresponds to an index number of a column, and the loop adds to the table all the columns in the order defined.
numbers are values defined by enumerations (named constants)
Best regards
for example : https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-estimation-of-reinforcement-weigh...
Message 14 of 29
HoshangMustafa
where one can find a guide to these index numbers of columns, e.g. what these index numbers would represent: 269, 270, 282, 271, 24, 149, 480?
Message 15 of 29
Already answered. No guide, you're on your own.
Message 16 of 29
HoshangMustafa
it would be more convenient if you were used TableColumnIndex as a variable rather than ColumnNumber, wouldn't it?
Message 17 of 29
Have you tried it? Could you explain or share your code, please?
Message 18 of 29
if this is what you wanted, note that to make the code more practical, you can create your own enumeration and use it as follows
Enum TCI
  BAR_NODE1 = 269
  BAR_NODE2 = 270
  BAR_NAME = 750
  BAR_LENGTH = 271
  BAR_SECTION_NAME = 24
  BAR_DEFL_UZ = 149
  CASE_NAME = 480
End Enum
    For Each TbColIndex In Array(TCI.BAR_NODE1, TCI.BAR_NODE2, _
                                 TCI.BAR_NAME, TCI.BAR_LENGTH, _
                                 TCI.BAR_SECTION_NAME, _
                                 TCI.BAR_DEFL_UZ, TCI.CASE_NAME)
      .AddColumn TbColIndex
    Next
Message 19 of 29
HoshangMustafa
I tried it this way:
Enum TCI
BAR_NODE1 = 269
BAR_NODE2 = 270
BAR_NAME = 750
BAR_LENGTH = 271
BAR_DEFL_UZ = 149
CASE_NAME = 480
End Enum
Sub module2()
Dim RobApp As RobotApplication
Set RobApp = New RobotApplication
With Table
.Select I_ST_BAR, "all"
Next
End With
End sub
Is it correct?
Message 20 of 29
hi @HoshangMustafa
Here is the updated file
Best Regards
file updated 03/18/2025
