API ROBOT - Results view
polylouis
polylouis
Hello everyone,
I would like to know if it is possible to see extreme values on panel like following picture :
(....CurrentResult = IRobotViewFeMapResultType.I_VFMRT_DETAILED_MOMENT_XX)
We see only max values but I would like to see max/min on the same capture.
I would like to find the api command to add on my code.
Thank you in advance,
Louis
Stephane.kapetanovic
hi @polylouis
here after enum
I_VFMRT_DETAILED_STRESS_XX = 483,
I_VFMRT_DETAILED_STRESS_YY = 484,
I_VFMRT_DETAILED_STRESS_XY = 485,
I_VFMRT_DETAILED_STRESS_Z = 486,
I_VFMRT_DETAILED_MEMBRANE_FORCE_XX = 492,
I_VFMRT_DETAILED_MEMBRANE_FORCE_YY = 493,
I_VFMRT_DETAILED_MEMBRANE_FORCE_XY = 494,
I_VFMRT_DETAILED_MOMENT_XX = 501,
I_VFMRT_DETAILED_MOMENT_YY = 502,
I_VFMRT_DETAILED_MOMENT_XY = 503,
I_VFMRT_DETAILED_SHEAR_STRESS_XX = 510,
I_VFMRT_DETAILED_SHEAR_STRESS_YY = 0x1FF,
I_VFMRT_DETAILED_SHEAR_FORCE_XX = 519,
I_VFMRT_DETAILED_SHEAR_FORCE_YY = 520,
I_VFMRT_DETAILED_DISPLACEMENT_XX = 537,
I_VFMRT_DETAILED_DISPLACEMENT_YY = 538,
I_VFMRT_DETAILED_ROTATION_XX = 546,
I_VFMRT_DETAILED_ROTATION_YY = 547,
I_VFMRT_DETAILED_ROTATION_Z = 549,
I_VFMRT_DETAILED_SOIL_REACTION_Z = 558,
I_VFMRT_PRINCIPAL_STRESS_1 = 487,
I_VFMRT_PRINCIPAL_STRESS_2 = 488,
I_VFMRT_PRINCIPAL_STRESS_1_2 = 490,
I_VFMRT_PRINCIPAL_STRESS_ANGLE = 489,
I_VFMRT_PRINCIPAL_MEMBRANE_FORCE_1 = 496,
I_VFMRT_PRINCIPAL_MEMBRANE_FORCE_2 = 497,
I_VFMRT_PRINCIPAL_MEMBRANE_FORCE_1_2 = 499,
I_VFMRT_PRINCIPAL_MEMBRANE_FORCE_ANGLE = 498,
I_VFMRT_PRINCIPAL_MOMENT_1 = 505,
I_VFMRT_PRINCIPAL_MOMENT_2 = 506,
I_VFMRT_PRINCIPAL_MOMENT_1_2 = 508,
I_VFMRT_PRINCIPAL_MOMENT_ANGLE = 507,
I_VFMRT_PRINCIPAL_SHEAR_STRESS_1_2 = 517,
I_VFMRT_PRINCIPAL_SHEAR_FORCE_1_2 = 526,
I_VFMRT_GLOBAL_DISPLACEMENT_X = 1302,
I_VFMRT_GLOBAL_DISPLACEMENT_Y = 1303,
I_VFMRT_GLOBAL_DISPLACEMENT_Z = 1304,
I_VFMRT_TOTAL_DISPLACEMENTS = 1305,
I_VFMRT_COMPLEX_STRESSES = 491,
I_VFMRT_COMPLEX_MEMBRANE_FORCES = 500,
I_VFMRT_COMPLEX_MOMENTS = 509,
I_VFMRT_COMPLEX_REINFORCE_TOP_MXX = 889,
I_VFMRT_COMPLEX_REINFORCE_TOP_MYY = 891,
I_VFMRT_COMPLEX_REINFORCE_BOTTOM_MXX = 890,
I_VFMRT_COMPLEX_REINFORCE_BOTTOM_MYY = 892,
I_VFMRT_DETAILED_DISPLACEMENT_Z = 531
Best regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
polylouis
Hello Stephane,
Thank you for your reply.
I already tried I_VFMRT_DETAILED_MOMENT_XX = 501 but it give me only min and not absolute values of min/max moment..
Do you have other idea ?
Louis
hi @polylouis
Value labels are set automatically function of diagram type and you cannot change, anotate or move them by API.
Try to :
set manually the dialogbox
make a better zoom on panel
test parameters that influence the presentation like WithDescription, Layer, Smoothing, MapScale, and so.
add other results to your note for understanding
Best regards
