API or macro to send bar forces to excel in certain order
me1205377
Message 1 of 19
me1205377
Greetings, if you could please write a small code to send bar forces to excel in this way i will be very grateful. it takes forever to manually read and type bar forces in excel in the following manner
side note i am not sure if it is too much to ask as i dont know how hard/easy it is to create this macro or addin . i will be happy to pay for this if it takes time.
moustafa elgaar
Replies (18)
Message 2 of 19
me1205377
I am using RSA2015  if it makes any difference
moustafa elgaar
Message 3 of 19
Romanich
Hi Moustafa,
Have you seen this thread?
https://forums.autodesk.com/t5/Autodesk-Robot-Structural/getting-internal-forces-from-RSA-to-XL-API/...
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 4 of 19
me1205377
yes Mr. Romanich  i have checked it and it contain similar spread sheets to what i need, but not quite the same  the order  must e exactly as in the attached picture. this is because i have to send theses results to another program who can only read RC column forces in this order:
for each column , the program need ( Fx , MYt , MYb, MZb, MZb ) in a text file.
i hope you can help me
moustafa elgaar
Message 5 of 19
me1205377
 (Fx , MYt , MYb, MZy, MZb )
this is the big picture
i start with robot , i get these forces in this particular  order into excel, then i change these cells to text format using "concatenate" function then  copy and paste in a text file and finally export to a program such as SP Column
moustafa elgaar
Message 6 of 19
marcinrakus
This is something You can start working with (see attachment). It is quite inefficient and I'm not sure about coordinate system in which the other application requires the data. This dumps all in local coordinate system of bar as is in RSA.
We can iterate this solution if needed.
Marcin
Message 7 of 19
me1205377
thank you very much for your help  it looks very promising
just few adjustment if it is not too much to ask  🙂
what ever  selection of bars i make in robot  say 5 bars , regardless of the  bar numbers being selected say ( 224,158,987,1526,3) . only bars with the numbering from 1 to 5 are sent to excel instead.
case number are also ignored , regardless of what set of cases i select from robot  only simple cases are sent not combinations
finally, the units, it would be great if forces are in (KN)  and Moment in (KN.M)
moustafa elgaar
Message 8 of 19
marcinrakus
Selection of bars - corrected.
Units changed to kN - corrected.
Selection of cases - this works different by API, so I added a field in excel (the green one), where You can enter Your selection. If it is empty by default full selection of simple cases, combinations and ponderations is taken into consideration.
Marcin
Message 9 of 19
me1205377
i accept it as a solution , just if you have some spare time, could you limit the decimal places to 3 numbers only  eg: "  2420.321 KN"  instead of "2420.32014568 KN"
moustafa elgaar
Message 10 of 19
marcinrakus
Rounded.
Marcin
Message 11 of 19
me1205377
thank you sir ,wish you some good karma
moustafa elgaar
Message 12 of 19
isabel.bras
It is possible to have the forces in a point in the middle of the bar?
Message 13 of 19
marcinrakus
In the macro You can see for example lines:
val1 = RobApp.Project.Structure.Results.bars.Forces.Value(bar.Number, casNumber, 0).FX / 1000
val2 = RobApp.Project.Structure.Results.bars.Forces.Value(bar.Number, casNumber, 1).FX / 1000
in which 0 means begin and 1 means end of a member. If You put 0.5 You will obtain results for middle point:
val3 = RobApp.Project.Structure.Results.bars.Forces.Value(bar.Number, casNumber, 0.5).FX / 1000
Marcin
Message 14 of 19
isabel.bras
When I try do run the macro, it appears an errorerro.png.
When I go to Debug it appears: erro2.png
Do you know what is happening?
Message 15 of 19
Stephane.kapetanovic
This code works ! Are you sure Robot and a model is open ?
Have you check references to Robot Object Model in visual basic editor (<tools> <references>) ?
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 16 of 19
isabel.bras
Hello
Can you explain how can I check the references?
Message 17 of 19
In your spreadsheet, press Alt+F11 to go to visual basic editor
Go to <Tools> and <Références> and then find Robot Object Model ver. xxx
Message 18 of 19
isabel.bras
yes, I'm using the correct version...
Message 19 of 19
isabel.bras
I reinstall Robot and solved the problem.
