Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Axial stiffness of concrete member
mustafahesenow
Advisor Advisor
mustafahesenow
How To reduce Axial stiffness for RC beam or RC column ?
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
Unfortunately it cannot be done in the same way as for IX, IY and IZ Smiley Sad
You can modify E value in the material properties (or just define its cross sections as smaller than it really is) and then adjust the above ones accordingly if you need to design reinforcement in this column or define its section by its properties instead.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
I haven't tested this as I have just thought about this option - what about using the elastic / partial stiffness reduction UX release?
Artur Kosakowski
mustafahesenow
Mustafa Hesenow
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Mustafa,
I have forwarded your request to the development team.
Artur Kosakowski
acostaU6S2R
Hi@Artur.Kosakowski,
I would like to know if it is already possible to change the axial stiffness of a RC Column or a RC beam.
