API-new project creation Python
Message 1 of 9
Hi all,
I have already used the Robot API through VBA and I am not trying to replicate some work with Python (I am relatively new to Python). I followed the methodology suggested here:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-amp-ironpython/m-p/7221364
and it works perfectly in terms of establishing the connection to Robot.
However, I was wondering what is the syntax for a new project creation as where I try to set up a new Project using the I_PT_SHELL example in the SDK documentation I cannot seem to get the syntax right.
I defined Robot as in the post above and tried the following syntax structures:
Robot.Project.New('I_PT_SHELL')
Robot.Project.New("I_PT_SHELL")
May I ask you if you could advise in this regard?
Thank you!
Replies (8)
Message 2 of 9
Quick update: I was also trying to run fully the script in the post of my initial question but I receive this error:
has anyone else experienced this before?
Message 3 of 9
JacquesGaudin
That must be because there is no open document.
Try to add a line to create a document:
from RobotOM import IRobotProjectType
project.New(IRobotProjectType.I_PT_SHELL)
Message 4 of 9
Hi @JacquesGaudin
yes, that was also my understanding but I could not get the syntax right. I was using the same format of the label creation but clearly it was not working.
Thank you very much for your help!
It might have been a trivial question, but I am a bit new to Python...thanks again!!
Message 5 of 9
golkrz
I am trying to use Robot API via python but I am struggling to use the data defined by Robot Object Model. I looked at SDK and I understand that the robotom.tlb needs to be added to the python IDE. Could you explain how did you manage to do that?
Message 6 of 9
JacquesGaudin
For plain CPython:
You need to install PythonNet and add a reference to `interop.RobotOM.dll`
import clr
from pathlib import Path
p = Path('c:/Program Files/Autodesk')
robot_dll_path = str(next(p.rglob('System/EXE/interop.RobotOM.dll')))
clr.AddReference(robot_dll_path)
import RobotOM
For IronPython:
import clr
robotom_path = "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2019\System\Exe\interop.RobotOM.dll"
clr.AddReferenceToFileAndPath(robotom_path)
import RobotOM
Then in both cases to create an instance of Robot application:
app = RobotOM.RobotApplication()
Message 7 of 9
In the snap shot below you can see that there is no attribute as "AddReference", but in all the code above it is there please help ..
Message 8 of 9
JacquesGaudin
What's the output of:
import clr
dir(clr)
Message 9 of 9
mmaso64U7Y
Python.Net package aliases to 'clr', which is in conflict with 'clr' package. As stated by @JacquesGaudin , you can check whether 'clr' is pointing to 'pythonnet' or to 'clr' using 'dir()' function.
To install 'pythonnet' run the following commands:
pip uninstall clr
pip install pythonnet
See this topic.
