(API) Macro for dumping all opened tables in Robot (with all tabs) to Excell
Rafal.Gaweda
Autodesk Support Autodesk Support
Message 1 of 20
Rafal.Gaweda
Autodesk Support
Autodesk Support
Wait patiently until "Dumping finished" message appears on screen
ANSI csv files are stored in windows %temp% (loaction can be changed in macro if one wants) so they can be reused if needed
(if files are not properly open in Excel, open VBA editor and play with code changing separators characters, relevant code marked in macro)
Rafal Gaweda
Replies (19)
Message 2 of 20
Rafal.Gaweda
Autodesk Support
Autodesk Support
Newer version in attachment
Rafal Gaweda
Message 3 of 20
Rafal.Gaweda
Autodesk Support
Autodesk Support
Corrected opening files in Excel
Rafal Gaweda
Message 4 of 20
ledinhchinh0409
hi. @Rafal.Gaweda
Thank you, this is very helpful. But can export results in the 'sheet' in an excel file instead of the 'excel file'  as it is now?
Message 5 of 20
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
Here you are
Rafal Gaweda
Message 6 of 20
ledinhchinh0409
hi. @Rafal.Gaweda
Thanks very much. However when I export to excel it does not have the desired format.
Message 7 of 20
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
Try attached.
If it does not work as you expect please change List Separator in Windows Regional Settings onto ";"
Rafal Gaweda
Message 8 of 20
piperr
This is amazing @Rafal.Gaweda !!!
Message 9 of 20
ledinhchinh0409
@Rafal.Gaweda
It worked very well. Thank you very much!
Message 10 of 20
Muhammed.OPERA
That's very useful, amazing @Rafal.Gaweda
Keep on Smiley Happy
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
Message 11 of 20
jmmarin
Thank you. It is very useful!!
Message 12 of 20
WALIDGIO
it does't work for my ROBOT 2025 and excel 2021
Message 13 of 20
Stephane.kapetanovic
hi @WALIDGIO
You must first create the tables in your project so that the program can read them
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
Message 14 of 20
LionelDallenne
Hi @Stephane.kapetanovic ,
As you said, robot tables need to be created so that the program can read them. However, it also only works when the table are visible and shown in Robot. Any ideas how to automate this? To make it more tangible, I would need the following table for instance to be retrieved (Results - Forces), hence autoatically opened in Robot.
Thanks!
Message 15 of 20
hi @LionelDallenne
Here is a brief example of the use of tables for the extraction of forces in bars
Best Regards
Message 16 of 20
LionelDallenne
Thanks @Stephane.kapetanovic
It seems I'm now able to create the table I need within Robot.
Thanks for your help so far.
Message 17 of 20
HoshangMustafa
I tried your excel file without success
Message 18 of 20
hi @HoshangMustafa
no problem here, are you sure you authorized the workbook macros when you opened it?
After downloading the file from the forum, you sometimes might need to unblock it via its properties to bypass security restrictions.
Best Regards
Message 19 of 20
LionelDallenne
Hi @HoshangMustafa,
please make sure as well to unblock the Excel file in the file properties in Explorer.
Best regards,
Message 20 of 20
hi @LionelDallenne
this is not the case it is an excel 97-2003, so no additional blocking
Best regards
