API generate CODE combinations
AbelSV78
AbelSV78
I am trying to create code combinations for Robot from VB.net. I am using this:
engine = robapp.Project.Structure.Cases.CodeCmbEngine
engine.Params.SelectCombinationType(RobotOM.IRobotCombinationType.I_CBT_ULS, True)
engine.Generate()
but it doesn't work. Perhaps I need to define params, but I don't know the variables and how to use it. Could you help me?
Thank you so much in advance
Rafal.Gaweda
Autodesk Support
Autodesk Support
    Dim r As New RobotOM.RobotApplication
    Dim q As RobotOM.RobotCodeCombinationEngine
    q = r.Project.Structure.Cases.CodeCmbEngine
    q.Params.GenType = RobotOM.IRobotCodeCmbGenerationType.I_CCGT_FULL
    q.Params.SelectCombinationType RobotOM.IRobotCombinationType.I_CBT_ULS, True
    q.Params.SelectCombinationType RobotOM.IRobotCombinationType.I_CBT_SLS, True
    q.Generate
Rafal Gaweda
AbelSV78
Thank you so much, but there is another problem:
"Incorrect definition of relations between case groups".
I have used different simple cases of different nature. I know the problem in Robot, but I don't know how to solve with API.
Regards
Rafal.Gaweda
Autodesk Support
Autodesk Support
Old example below, something may not work but at least it should give you idea how to play with it
(do not use Kernel in your code ; just example)
                Public Sub CodeCombinations(ByVal ccE As RobotOM.RobotCodeCombinationEngine, ByVal k As KernelOM.RobotKernel)
                                Dim KccE As KernelOM.RobotCodeCombinationEngine
                                KccE = k.Structure.Cases.CodeCmbEngine
                                'Dim ccG As RobotOM.RobotCodeCmbGroup
                                'Dim KccG As KernelOM.RobotCodeCmbGroup
                                Dim cas_lst As String = ""
                                Const COMB_TYPES As Integer = 7
                                'Const COMB_GROUPS As Integer = 6
                                Const COMB_DECID_VAL As Integer = 14
                                'Const COEF_COUNT As Integer = 13
                                Dim i As Integer
                                'Dim j As Integer
                                Dim q As Integer
                                KccE.Params.GenType = ccE.Params.GenType
                                'cases
                                Dim casCol As RobotOM.IRobotCollection
                                Dim KcasCol As KernelOM.IRobotCollection
                                casCol = ccE.Params.ActiveCases
                                KcasCol = KccE.Params.ActiveCases
                                Dim cinfo As RobotOM.RobotCodeCmbActiveCaseInfo
                                Dim Kcinfo As KernelOM.RobotCodeCmbActiveCaseInfo
                                For i = 1 To KcasCol.Count
                                                Kcinfo = KcasCol.Get(i)
                                                For q = 1 To casCol.Count
        cinfo = casCol.Get(q)
        If cinfo.CaseNumber = Kcinfo.CaseNumber Then
        Exit For
                                                Next
                                                If cinfo.IsSelected Then
        Kcinfo.IsSelected = cinfo.IsSelected
        Kcinfo.Coefficient = cinfo.Coefficient
                                Next
                                If ccE.Params.AllBars Then
                                                KccE.Params.AllBars = ccE.Params.AllBars
                                Else
                                                KccE.Params.BarSel = ccE.Params.BarSel
                                If ccE.Params.AllNodes Then
                                                KccE.Params.AllNodes = ccE.Params.AllNodes
                                Else
                                                KccE.Params.NodeSel = ccE.Params.NodeSel
                                KccE.Params.ExtremalSnowFactor = ccE.Params.ExtremalSnowFactor
                                If KccE.Params.GenType = KernelOM.IRobotCodeCmbGenerationType.I_CCGT_SIMPLIFIED Then
                                                For i = 1 To COMB_DECID_VAL
        KccE.Params.SelectDecidingValue(i, ccE.Params.IsDecidingValueSelected(i))
                                                Next
                                                KccE.Params.SelectDecidingValue(KernelOM.IRobotCodeCmbDecidingValueType.I_CCDVT_REACTIONS, _
        ccE.Params.IsDecidingValueSelected(RobotOM.IRobotCodeCmbDecidingValueType.I_CCDVT_REACTIONS))
                                'For q = 1 To ccE.Params.Regulations.Actions.Count
                                '               KccE.Params.Regulations.Actions.SetNature(q, ccE.Params.Regulations.Actions.GetNature(q))
                                '               KccE.Params.Regulations.Actions.SetName(q, ccE.Params.Regulations.Actions.GetName(q))
                                '               For j = 0 To COEF_COUNT
                                '                               KccE.Params.Regulations.Actions.SetCoeff(q, j, ccE.Params.Regulations.Actions.GetCoeff(q, j))
                                '               Next
                                'Next
                                'Dim lim_state As RobotOM.IRobotLimitState
                                'Dim cmb_typ As RobotOM.IRobotCodeCmbCombType
                                'Dim cmb_nam As String = ""
                                'Dim d_c As Short, l_c As Short, a_c As Short, s_c As Short
                                'For i = 1 To ccE.Params.Regulations.Combinations.Count
                                '               ccE.Params.Regulations.Combinations.Get(i, lim_state, cmb_typ, cmb_nam, d_c, l_c, a_c, s_c)
                                '               KccE.Params.Regulations.Combinations.[New](lim_state, cmb_typ, cmb_nam, d_c, l_c, a_c, s_c)
                                'Next
                                'Try
                                '               q = 0
                                '               While True
                                '                               KccE.Params.SelectCombination(q, ccE.Params.IsCombinationSelected(q))
                                '                               q += 1
                                '               End While
                                'Catch ex As Exception
                                '               'end of combinations
                                'End Try
                                'combinations
                                For i = 0 To COMB_TYPES
                                                If ccE.Params.IsCombinationTypeSelected(i) Then
        KccE.Params.SelectCombinationType(i, True)
                                                Else
        KccE.Params.SelectCombinationType(i, False)
                                Next
                                'groups
                                'For i = 0 To COMB_GROUPS
                                '               For j = 0 To ccE.Params.Groups.GetCount(i)
                                '                               ccG = ccE.Params.Groups.Get(i, j)
                                '                               For q = 1 To ccG.CaseCount
                                '                                               If ccG.IsFull Then
                                '                                                               'KccG.AddAll()
                                '                                               End If
                                '                               Next
                                '                               KccE.Params.Groups.[New](i, ccG.Operator, cas_lst)
                                '                               cas_lst = ""
                                '               Next
                                'Next
                                'relations
                                'Dim crel As RobotOM.RobotCodeCmbGroupRelation
                                'Dim Kcrel As KernelOM.RobotCodeCmbGroupRelation
                                'For q = 0 To COMB_TYPES
                                '               crel = ccE.Params.Relations.Get(q)
                                '               Kcrel = KccE.Params.Relations.Get(q)
                                'Next
                                k.Structure.Cases.CodeCmbEngine.Generate()
                End Sub
Rafal Gaweda
AbelSV78
Hi, finally I have found out this:
If norma.Text = "EUROCODE" Then
robapp.Project.Preferences.SetActiveCode(RobotOM.IRobotCodeType.I_CT_STEEL_STRUCTURES, "UNE-EN 1993-1:2005/AC:2009")
robapp.Project.Preferences.SetActiveCode(RobotOM.IRobotCodeType.I_CT_CODE_COMBINATIONS, "EN 1990:2002")
Dim engine As RobotOM.IRobotCodeCombinationEngine
Dim codecombination As RobotOM.RobotCodeCombinationEngine
Dim cmbparams As RobotOM.IRobotCodeCmbGenerationParams
codecombination = robapp.Project.Structure.Cases.CodeCmbEngine
codecombination.Params.GenType = RobotOM.IRobotCodeCmbGenerationType.I_CCGT_FULL
codecombination.Params.SelectCombinationType(RobotOM.IRobotCombinationType.I_CBT_ULS, True)
cmbparams = robapp.Project.Structure.Cases.CodeCmbEngine.Params
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_PERMANENT, RobotOM.IRobotCodeCmbOperator.I_CCO_AND, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_EXPLOATATION, RobotOM.IRobotCodeCmbOperator.I_CCO_AND_OR, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_WIND, RobotOM.IRobotCodeCmbOperator.I_CCO_EXCLUSIVE_OR, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_SEISMIC, RobotOM.IRobotCodeCmbOperator.I_CCO_EXCLUSIVE_OR, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_SNOW, RobotOM.IRobotCodeCmbOperator.I_CCO_AND, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_ACCIDENTAL, RobotOM.IRobotCodeCmbOperator.I_CCO_AND, "0")
cmbparams.Groups.[New](RobotOM.IRobotCaseNature.I_CN_TEMPERATURE, RobotOM.IRobotCodeCmbOperator.I_CCO_AND, "0")
codecombination.Generate()
HI Rafal Gaweda,
plz, I need help ...
How to use relations between groups with VBA
PERMANENT "G1" And "G2"
EXPLOITATION "Q1" OR"Q2"
"Definition of relations between groups. Definition of relations between groups can be illustrated by means of the matrix whose elements are group numbers. All groups whose numbers are located in the same matrix row are in the same relation with each other (either AND or AND_OR). Whereas among the matrix rows the relation EXCLUSIVE_OR occurs. ."
How to do relation between "G1" And "G2" with VBA plz
Thank ...
