Dynamo Plug-in for Robot Structural Analysis
Rafal.Gaweda
Autodesk Support Autodesk Support
LeeCastro
Dynamo Plug-in for Robot Structural Analysis 2018 is available?
Marque Aceitar como Solução e clique em Curtir.
Select Accept as Solution and click on Like
Li Chong Lee, DSc.
LinkedIn Instagram | Facebook | Twitter  | YouTube
Participante da Comunidade de Usuários Autodesk Brasil
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @LeeCastro
Please navigate to https://dynamopackages.com/ and search for Structural Analysis for Dynamo package
Artur Kosakowski
LeeCastro
I FIND IT!!!
TKS.
Li Chong Lee, DSc.
Hi Artur,
I used the Structural Analysis library successfully to control and run Robot from Dynamo. However, I found that the functions available through the library are limited and I do not have all the functionality I require to build the models I require. For instance, I could not find an option of applying a variable surface load to represent increasing ground pressure on a vertical wall.
I would like to write my own library but could not find any guidance on how this can be done such as relevant syntax to write Python scripts in Dynamo. Is it possible to see some example code demonstrating how these nodes are set up in Dynamo?
Best wishes
Rami
