(API) Excel VBA - Use FreeNum method and get load record num
cool.stuff
cool.stuff
Hi!!
I have a structure with multiple simple cases. Each simple case has multiple load records of various types.
I am trying to create a new load record in existing simple cases but I want to use the freenum method to generate that load record and get its number.
So far I have this code:
Dim SimpleCase As RobotSimpleCase
Dim caseNum As Integer
caseNum = Cells(10, 2)
Set SimpleCase = robapp.Project.Structure.Cases.Get(caseNum)
SimpleCase.Records.New I_LRT_BAR_UNIFORM
Dim recordNum As Integer
recordNum = SimpleCase.Records.Count
Dim LoadRecord As RobotLoadRecord
Set LoadRecord = SimpleCase.Records.Get(recordNum)
But it is missing the FreeNumber method..
My idea is that with the FreeNumber method I can get the right load record, otherwise I dont know if I get it..
Can some help please?
Many thanks in advance!!! 🙂
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @cool.stuff
There is no freenumber for load records.
You may use Records.New...
Rafal Gaweda
cool.stuff
Many thanks for your answer @Rafal.Gaweda !! 🙂
So, if I use Count method, it will always give me the laod record that I create? Or is there another way of get the number of the last created load record?
Many thanks!! 🙂
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @cool.stuff
According to documentation Records.New returns record number.
Rafal Gaweda
