(API) Excel VBA - Node displacement
cool.stuff
cool.stuff
Hi!!!
Can someone explain waht does it mean:
I_NDRV_UX : = 0
I_NDRV_UY : = 1
I_NDRV_UZ : = 2
I_NDRV_RX : = 3
I_NDRV_RY : = 4
I_NDRV_RZ : = 5
I_NDRV_ALPHA : = 8
I_NDRV_BETA : = 9
I_NDRV_GAMMA : = 10
The first 6 I understand it is the displacements and rotation, but what does mean alpha, beta and gamma please?
Many thanks!
  • VBA
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @cool.stuff
My guess:
Rafal Gaweda
cool.stuff
Many thanks for your answer @Rafal.Gaweda !! 🙂
So, alpha, beta and gamma are the angle of the support right? 🙂
Another doubt: though API I can only set up the nodal displacements, right? I cannot define nodal velocity or acceleration right?
Many thanks!! 🙂
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @cool.stuff
Only Body Forces and Centrifugal Forces are not implemented in API.
Rafal Gaweda
cool.stuff
Thanks for your answer!!!
I am sorry but I did not understand..
From what is presented in API, I do not think it is possible..
But is it or not? 🙂
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @cool.stuff
Example
                    if (icase.Records.Get(i).Type == IRobotLoadRecordType.I_LRT_BAR_UNIFORM || icase.Records.Get(i).Type == IRobotLoadRecordType.I_LRT_NODE_FORCE
                        || icase.Records.Get(i).Type == IRobotLoadRecordType.I_LRT_NODE_DISPLACEMENT || icase.Records.Get(i).Type == IRobotLoadRecordType.I_LRT_NODE_VELOCITY
                        || icase.Records.Get(i).Type == IRobotLoadRecordType.I_LRT_NODE_ACCELERATION || icase.Records.Get(i).Type == IRobotLoadRecordType.I_LRT_NODE_FORCE_IN_POINT
                        || icase.Records.Get(i).Type == IRobotLoadRecordType.I_LRT_BAR_TRAPEZOIDALE || icase.Records.Get(i).Type == IRobotLoadRecordType.I_LRT_BAR_DILATATION
                        || icase.Records.Get(i).Type == IRobotLoadRecordType.I_LRT_BAR_FORCE_CONCENTRATED || icase.Records.Get(i).Type == IRobotLoadRecordType.I_LRT_BAR_THERMAL
                        || icase.Records.Get(i).Type == IRobotLoadRecordType.I_LRT_LINEAR_ON_EDGES)
                        CopyStdRecord(icase, Newcase, i, Scasefactor);
        public void CopyStdRecord(RobotSimpleCase icase, RobotSimpleCase Newcase, int i, double Scasefactor)
            RobotLoadRecord irec = (RobotLoadRecord)icase.Records.Get(i);
            RobotLoadRecord irecn = (RobotLoadRecord)Newcase.Records.Create(irec.Type);
            irecn.Objects.AddText(irec.Objects.ToText());
            for (short iic = 0; iic <= 5; iic++)
                irecn.SetValue(iic, irec.GetValue(iic) * Scasefactor);
            for (short iid = 6; iid <= 15; iid++)
                irecn.SetValue(iid, irec.GetValue(iid));
Rafal Gaweda
cool.stuff
Many thanks for your help and for the example @Rafal.Gaweda !! :))
