(API) Command VBA Projection Capture of a view
Message 1 of 147
I have a problem with my macro. The command of projection in 3D doesn't work. My view stay in XZ plane.
robapp.Window.Activate
Set mavueRobot = robapp.Project.ViewMngr.CreateView(1)
mavueRobot.Projection = I_VP_3DXYZ
mavueRobot.Visible = True
mavueRobot.Redraw (True)
I want also make a capture of my model with diagram of results. Have you an example of code for it ?
I would like to get for final result the exemple in attachment.
Replies (146)
Message 41 of 147
Maybe you can find the solution in my VBA codes.
I send you the file text of the model.
Message 42 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
As far as I can see there are no loads is case 1 and case 3 in model.
For the model on movie I have created sw in case 1 and some loads in casse 3.
Your code works fine.
Rafal Gaweda
Message 43 of 147
The case 1 and 2 are defined in the text file. The case 3 is defined in VBA. Do you need Excel file to verify ?
Message 44 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
Yes, but loads assigned directly to FEs are no displayed
Please attach.
Rafal Gaweda
Message 45 of 147
I would like to have the moment My on the view, I suppose it's a command like
mavueRobot.ParamsFeMap.CurrentResult = I_VFMRT_COMPLEX_REINFORCE_TOP_MXX
maybe
mavueRobot.ParamsFeMap.CurrentResult = I_VBMRT_NTM_MY
Sub cree_vues_resultats()
Dim mavueRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
Set mavueRobot = robapp.Project.ViewMngr.GetView(1) ' it seems CreateView makes this strange affect, use GetView instead
mavueRobot.ParamsDisplay.Set I_VDA_OTHER_RULER, True
robapp.Project.ViewMngr.Refresh
' displaying map
mavueRobot.ParamsFeMap.WithDescription = True
mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SYMBOLS, False
For i = 1 To 26
mavueRobot.Selection.Get(I_OT_CASE).FromText (i) ' selecting case for results display
ecran_capture = "moments My - Cas " & i
mavueRobot.Redraw (0)
Call screen_capture
Next i
End Sub
Message 46 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
maybe
VFMRT means ViewFEMapResultsType -> this works for  mavueRobot.ParamsFeMap.CurrentResult
VBMRT means ViewBarMapResultType
so I guesss you look for :
I_VFMRT_COMPLEX_REINFORCE_TOP_MYY    or
I_VFMRT_COMPLEX_REINFORCE_BOTTOM_MYY     or
I_VFMRT_DETAILED_MOMENT_YY
Rafal Gaweda
Message 47 of 147
My project is a Portique Plan with bar so I looking for My (Diagrams).
Can you correct my macro ?
Do you know the command to clean all the screen captures ?
Message 48 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
' displaying My diagram
mavueRobot.ParamsDiagram.Set I_VDRT_NTM_MY, True
Rafal Gaweda
Message 49 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
For i = 1 To robapp.Project.PrintEngine.ScreenCaptures.Count
robapp.Project.PrintEngine.ScreenCaptures.Remove robapp.Project.PrintEngine.ScreenCaptures.Get(1)
Next i
Rafal Gaweda
Message 50 of 147
Hi this commands don't work
mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_NODE_NUMBERS = True
mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_BAR_NUMBERS = True
Message 51 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
Try this:
mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_NODE_NUMBERS, True
mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_BAR_NUMBERS, True
RobApp.Project.ViewMngr.Refresh
Rafal Gaweda
Message 52 of 147
It doesn't work
error
I would like also change the size of symbols like :
mavueRobot.ParamsDisplay.SymbolSize = 5
This command doesn't change anything.
Message 53 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
I asked you to use this syntax:
Rafal Gaweda
Message 54 of 147
Ok sorry and for the syze of symbols ?
Message 55 of 147
Re SymbolSize; is it correct that this only takes an integer, and that the symbolsize represented in Robot is ten times of this?
E.g. SymbolSize = 2 gives a symbol size in robot of 20.
Similarly SymbolSize = 1.5 gives 20, and SymbolSize = 1.4 give 10.
Message 56 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
and that the symbolsize represented in Robot is ten times of this?E.g. SymbolSize = 2 gives a symbol size in robot of 20.
Yes it is like that. 1 in API coresponds to 10 in Robot.
Rafal Gaweda
Message 57 of 147
It doesn't work, can you send me an example ?
'mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_NODE_NUMBERS = True
'mavueRobot.ParamsDisplay.Set I_VDA_STRUCTURE_BAR_NUMBERS = True
mavueRobot.ParamsDiagram.Set I_VDRT_NTM_FX, False
mavueRobot.ParamsDiagram.Set I_VDRT_NTM_FZ, False
mavueRobot.ParamsDiagram.Set I_VDRT_NTM_MY, False
'mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_OFFSETS, True
mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_SHAPE, True
mavueRobot.ParamsDisplay.Set I_VDA_ADVANCED_ELASTIC_FOUNDATION, True 'afficher sol elastique
'mavueRobot.ParamsDisplay.Set I_VDA_FE_PANEL_THICKNESSES, True
'mavueRobot.ParamsDisplay.Set I_VDA_SECTIONS_COLORS, True
mavueRobot.ParamsDisplay.SymbolSize = 2
Message 58 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 59 of 147
I'd like to ask in the view this :
Reaction Fx
How can I make it ?
Message 60 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
Reaction Fx
Unfortunately it is not implemented in API.
Rafal Gaweda
