allowable bearing capacity of soil
Message 1 of 9
please can i alter soil bearing capacity without providing soil parameters from soil investigation?
Replies (8)
Message 2 of 9
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 3 of 9
thank a bunch bro
Message 4 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Would you mind marking @mustafahesenow's post (thank you) as the solution so that it is easier to find? Thank you.
Artur Kosakowski
Message 5 of 9
I am trying to design foundation in Robot for some days. But could not get proper result. Is there any option to get proper design?
Check my picture, how much reaction load but how small the footing size is coming!!!!FDN design problem.JPG
Message 6 of 9
mustafahesenow
Hi @Anonymous
send me the model please.
Mustafa Hesenow
LinkedIn
Message 7 of 9
please check.
Message 8 of 9
mustafahesenow
Mustafa Hesenow
LinkedIn
Message 9 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Assuming that you want to design a foundation in node 6 then the model you sent don't have any combinations defined whereas it seems you used COMB1 for the design. Could you attach the model after exporting the reactions in node 6 from the model to the foundation model (in other words with the  Foundation 6 already being creayed in the Rc Inspector) so that it is easier to investigate the situation you described?
Artur Kosakowski
