ALGERIAN CODE
StefanoPasquini6790
ALGERIAN CODE
StefanoPasquini6790
Hi everyone,
is there someone that can suggest me wich code to use in Robot for a Algerian Structure.
RC structure code
steel structure code
loads (wind and snow)
seismic code
Greetings at all
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Artur.Kosakowski
Autodesk Support
Autodesk Support
I think you may try to use the French codes. The Algerian seismic code is RPA 99 which is available in Robot.
On the other hand I assume that the request to use particular design codes should be stated in the project's specification delivered by the project 'owner'.
Artur Kosakowski
