solid object
solid object
MUHANNAD.ABU_ABDO
Message 1 of 11
solid object
MUHANNAD.ABU_ABDO
hello to all .. how i can model this pier as solid object ?!
Muhannad M.Abu Abdo
Structural Design Engineer
Replies (10)
Message 2 of 11
Use solid model type template.  Draw a 2D contour, extrude it to suit the depth.   There are many posts on this forum already about it.
Message 3 of 11
MUHANNAD.ABU_ABDO
can you explain with photos plz .. you know the idea is easy to understand but the implementation is difficult
Muhannad M.Abu Abdo
Message 4 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
tricky part : http://screencast.com/t/I09U4ee2y
Rafal Gaweda
Message 5 of 11
MUHANNAD.ABU_ABDO
Many Many Many thanks the legend of robot .. when i do it i found this problem .. i tried to make properly mesh with element size but it's not okay at the end ?
Muhannad M.Abu Abdo
Message 6 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please
Rafal Gaweda
Message 7 of 11
MUHANNAD.ABU_ABDO
http://www.filemail.com/d/tebcejugjmgvjtw
Muhannad M.Abu Abdo
Message 8 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
http://screencast.com/t/dKmC6EdvrEJf
file attached
Rafal Gaweda
Message 9 of 11
MUHANNAD.ABU_ABDO
Many thanks sir .. i'm grateful to you .. thanks a lot
Muhannad M.Abu Abdo
Message 10 of 11
MUHANNAD.ABU_ABDO
When i copy the object ... the deformation appear in the top soild object as in the photo .. what is the solution for this ??
Muhannad M.Abu Abdo
Message 11 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
