Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
solid object
10 REPLIES 10
Message 1 of 11
MUHANNAD.ABU_ABDO
993 Views, 10 Replies
solid object
hello to all .. how i can model this pier as solid object ?!
Muhannad M.Abu Abdo
Structural Design Engineer
10 REPLIES 10
Message 2 of 11
in reply to: MUHANNAD.ABU_ABDO
Use solid model type template.  Draw a 2D contour, extrude it to suit the depth.   There are many posts on this forum already about it.
Message 3 of 11
MUHANNAD.ABU_ABDO
can you explain with photos plz .. you know the idea is easy to understand but the implementation is difficult
Muhannad M.Abu Abdo
Message 4 of 11
tricky part : http://screencast.com/t/I09U4ee2y
Rafal Gaweda
Message 5 of 11
Many Many Many thanks the legend of robot .. when i do it i found this problem .. i tried to make properly mesh with element size but it's not okay at the end ?
Muhannad M.Abu Abdo
Message 6 of 11
File please
Rafal Gaweda
Message 7 of 11
http://www.filemail.com/d/tebcejugjmgvjtw
Muhannad M.Abu Abdo
Tags (1)
Message 8 of 11
http://screencast.com/t/dKmC6EdvrEJf
file attached
Rafal Gaweda
Message 9 of 11
Many thanks sir .. i'm grateful to you .. thanks a lot
Muhannad M.Abu Abdo
Message 10 of 11
When i copy the object ... the deformation appear in the top soild object as in the photo .. what is the solution for this ??
Muhannad M.Abu Abdo
Tags (1)
Message 11 of 11
