some deja vu.
After installation of Revit 2021.1:
- missing smxx export option
- also direct transfer didn't work, says "Object reference not set to an instance of an object"
- tried to install "revit to robot extension", didn't helpd
- Robot installed latest version with latest updates.
Please can anybody check, if it's for all.
Seems must reinstall Revit to 2022.0 ๐
Solved by okapawal. Go to Solution.
Yes, I need to confirm that the installation of Revit 2022.1 damage the link between Revit and Robot.
I also blocks some functionality in RSA, including Steel Connection modules, Add-ins menu and Typical Reinforcement dialogs in provided reinforcement modules.
I'm terribly sorry for the situation. We will prepare hotfix as soon as possible.
We don't have solution yet. The temporary workaround is to uninstall Robot 2022.
Then install it again plus Robot 2022 Hotfix1. Everything returns to the correct state.
This is a very very bad news.
this problem appear only some month ago, and now we have the same issue?
I'm going to have fear to install nextrevit updates......
I have to correct my previous post, in my Workstation this issue is not happen...right now!
It has been answered in the related post
If you are experiencing missing component in Robot 2022 after installation of Revit 2022 Hotfix1 or Update 2022.1, which includes:
- add-in menu is empty
- steel connection design is not working
- a few dialogs in RC Column design don't open
Here is an additional installation which fixes the problem:
Download the file and run installation.
