Welcome to Autodeskโ€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
After Revit 2022.1 installation cant export to Robot
9 REPLIES 9
Message 1 of 10
GatisM
1402 Views, 9 Replies
some deja vu.
After installation of Revit 2021.1:
- missing smxx export option
- also direct transfer didn't work, says "Object reference not set to an instance of an object"
- tried to install "revit to robot extension", didn't helpd
- Robot installed latest version with latest updates.
Please can anybody check, if it's for all.
Seems must reinstall Revit to 2022.0 ๐Ÿ˜ž
9 REPLIES 9
Message 2 of 10
kaspars
in reply to: GatisM
Can somebody check this please? Or only for me something went wrong.
Message 3 of 10
okapawal
in reply to: GatisM
Yes, I need to confirm that the installation of Revit 2022.1 damage the link between Revit and Robot.
I also blocks some functionality in RSA, including Steel Connection modules, Add-ins menu and Typical Reinforcement dialogs in provided reinforcement modules.
I'm terribly sorry for the situation.  We will prepare hotfix as soon as possible.
Waldemar Okapa
Sr Product Owner
Message 4 of 10
okapawal
in reply to: GatisM
We don't have solution yet.  The temporary workaround is to uninstall Robot 2022.
Then install it again plus Robot 2022 Hotfix1.  Everything returns to the correct state.
Waldemar Okapa
Sr Product Owner
Message 5 of 10
This is a very very bad news.
this problem appear only some month ago, and now we have the same issue?
I'm going to have fear to install nextrevit updates......
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 6 of 10
I have to correct my previous post, in my Workstation this issue is not happen...right now!
PasProStudio
Message 7 of 10
do you have a solution now ?
Tags (1)
Message 8 of 10
do you have a solution for this problem now ?
Message 9 of 10
It has been answered in the related post
https://forums.autodesk.com/t5/robot-structural-analysis-forum/arsa-2022-disappearing-of-collaborati...
If you are experiencing missing component in Robot 2022 after installation of Revit 2022 Hotfix1 or Update 2022.1, which includes:
- add-in menu is empty
- steel connection design is not working
- a few dialogs in RC Column design don't open
Here is an additional installation which fixes the problem:
REX_Framework.msi
Download the file and run installation.
Waldemar Okapa
Sr Product Owner
Message 10 of 10
RAHF911
in reply to: GatisM
I HAVE SAME PROBLEM IN THE ROBOT EXTENSION REVIT 2022 IT CANT INSTALL WAY?????
