Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Accidentally subdivided all the beams in my model
3 REPLIES 3
brisid.isufi
173 Views, 3 Replies
I accidentally subdivided all the beams in my model. I selected all the elements, and then I applied Edit - Intersect, but I forgot that I had the shells already meshed. I learned my lesson, and I will be more careful next time, but is there any quick way to merge my beams back to their initial configuration? I should mention that I cannot go back using "undo", because I will loose a lot of work that way.
Labels (3)
3 REPLIES 3
Hi @brisid.isufi
Have you tried the undo command ? Another solution is to quit without saving.
Best regards
brisid.isufi
in reply to: brisid.isufi
Unfortunately "undo" is not feasible because I made the mistake some days ago, not sure exactly when, and I don't want to loose my work.
Technology Administrators
