Robot Structural Analysis Forum
Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
Did you mean:Ā
Accidentally subdivided all the beams in my model
3 REPLIES 3
brisid.isufi
197 Views, 3 Replies
I accidentally subdivided all the beams in my model. I selected all the elements, and then I applied Edit - Intersect, but I forgot that I had the shells already meshed. I learned my lesson, and I will be more careful next time, but is there any quick way to merge my beams back to their initial configuration? I should mention that I cannot go back using "undo", because I will loose a lot of work that way.
Labels (3)
3 REPLIES 3
Hi @brisid.isufi
Have you tried the undo command ? Another solution is to quit without saving.
Best regards
brisid.isufi
in reply to: brisid.isufi
Unfortunately "undo" is not feasible because I made the mistake some days ago, not sure exactly when, and I don't want to loose my work.
Technology Administrators
