About the Local Coordinate System of Solid Elements
n-yamaguchiDG57M
Message 1 of 10
n-yamaguchiDG57M
Hello.
The stresses of solid elements are expressed in the local coordinate system.
Where can I find the orientation of the local coordinate system of a solid element?
Also, I would appreciate it if you could tell me how to display the element number of a solid element.
Best regards
Replies (9)
Message 2 of 10
Stephane.kapetanovic
https://help.autodesk.com/view/RSAPRO/2025/ENU/?guid=GUID-EB6B9297-13CD-411A-994D-A5EB37D86ADF
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 3 of 10
n-yamaguchiDG57M
hi Stephane.kapetanovic
I understand the coding rules.
I don't understand the contents of the attachment. Also, Where can I see the solid element number?
Best regards
Message 4 of 10
hi @n-yamaguchiDG57M
On the pdf file, I seem to see several flat panels outlining a volume. Is this really a solid? Can you share your file?
Best Regards
Message 5 of 10
n-yamaguchiDG57M
Excuse me. When I try to attach it, the extension( .rtd) is not recognized.
How do I share it?
[The content type (application/octet-stream) of the attachment wellhead concrete solid analysis model.rtd did not match the file extension and was removed.]
  • 添付ファイル wellhead concrete solid analysis model.rtd のコンテンツタイプ(application/octet-stream)がファイル拡張子に一致しないため、削除されました。
Message 6 of 10
Romanich
Hi @n-yamaguchiDG57M,
zip the file first.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 7 of 10
n-yamaguchiDG57M
I tried compressing the data and attaching it. Can you confirm it? Best regards.
Message 8 of 10
n-yamaguchiDG57M
hi Romanich
Thank you very much for the advice.
Message 9 of 10
your file contains background drawings. i can't open it.
Message 10 of 10
n-yamaguchiDG57M
We will share the data with the background link cut.
Best regards
