I am looking for more information on how to access code check information with the ROBOT api. The following link indicates that it is possible to access this information through the API.
Is it possible to run member code check using API in Robot Strucutral Analysis (autodesk.com)
Code Check Data
I understand we can access member the data in the Properties tab through assigned section & material labels, while NTM tab & Displacement tab Data may be accessed through the RobotBarResultsServer. How does one access the Data in the Code Check tab as shown?
Thank you and regards,
Liam McHale
