2023: Robot to Revit integration
alexpapado1821
Message 1 of 22
alexpapado1821
I inserted the analytical model from Robot to Revit. How can I produce the physical model?
Replies (21)
Message 21 of 22
umut.akparlar
Hello Pawel,
We can use RSA for code-based rebar design and detailing so why do we need to create rebars again in Revit from scratch? Rebars can be transferred between robot and Revit without needing a third part plug in.
We have the calculations and provided reinforcement in 2D/3D using robot but we still need third party plug ins. I am not sure this is the logical/feasible way to do it.
Regards
Message 22 of 22
PedroSousaRego
Hi, I am doing my dissertation on the topic of interoperability between Revit and Robot (applied to a structural project) and one of the main objectives of my dissertation was to study the errors that occur when the provided reinforcement was sent from Robot to Revit (after being designed based on the design code, in my case EuroCode).
The problem is that I'm using version 23 of both Revit and Robot and from what I just realized on this forum, it's no longer possible to send the provided reinforcement back to Revit. Therefore, my questions are:
1) the reinforcement will always have to be made manually in Revit (visually copying what was generated in the Robot) and is there any Revit extension that facilitates the reinforcement modeling?
2) is there any Revit extension that allows automatic reinforcement generation based on EuroCode?
3) is there any Revit extension that can read the results of the static analysis and the required reinforcement areas that can be transferred from the Robot and, based on this, automatically generates a reinforcement solution that respects EuroCode?
I really appreciate any kind of help, since this change of no armor transfer completely changes the purpose of my dissertation and I need to find a solution/alternative.
Regards
