Panel won't/takes a long time to mesh
1234eddie
1234eddie
Hi all,
I have a structure with  panels, all panels created in the same way. but 1 panel takes forever/ even let robot crash when i want to generate the mesh.
the picture below shows the structure.
Does anyone know why this might happen?
File is attached. i'm using RSA 2022
Thanks in advance.
Gr Edward
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @1234eddie
Edit circular opening properties and switch on discretization (16 parts corresponding to defined rigid link points)
Krzysztof Wasik
1234eddie
thanks @Krzysztof_Wasik
it solved my problem, but i don't get it. because the other panel has also openings in it without discretization, and that one has no problems to mesh.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @1234eddie
It seems like a kind of singularity in meshing procedure. As far as I could check activating Regular mesh for that panel also helps.
Krzysztof Wasik
