For RSA versions greater than 2019, it seems that the only way to combine a harmonic case with a static case is to neglect the damping. However, neglecting the damping does not seem to me to be an appropriate solution to determine the dynamic loads. Indeed, damping participates largely in the dynamic response of the structure. In addition, for a steel structure walkway as in the example of the French 15th webinar, it is recommended to use a constant damping of 0.4% for the SLS analysis and to change to 2% at the ULS for a case of vandalism or manifestation which authorizes a greater damping: these effects are completely erased if the damping is removed in the case of harmonic analysis. Moreover, the entry into resonance of a structure without damping can lead to a total divergence of the solution which will tend towards infinity. I found on the structure of a metal footbridge which presented in the harmonic analysis with damping of 0.4% a maximum deflection of 5 cm and which passes to several tens of meters if I neglect the damping. It is then impossible to derive anything from the corresponding ELS manual combination.
What are your recommendations to determine the combined effects of a static case and a harmonic case with versions of RSA greater than 2019 please? (for example when implementing the recommendations of the French SETRA guide for pedestrian bridges).
It is always possible to determine the maximum deflections and stresses in the static cases and in the harmonic analysis separately and then to sum manually, but there is a risk of adding maximum stresses which do not occur at the same place of the structure. This solution goes in the sense of security but is not very strict, unless you combine the results from node by node in an array, but this is a lot of extra work when it was done automatically on the older versions of Robot.
Than you very much for suggestions and / or clarifications on this subject.
