Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
You can't see the wall
4 REPLIES 4
kaidats
1002 Views, 4 Replies
I am wanting to model the wall, but nothing can be seen. Why is this?
4 REPLIES 4
Jamhmer_Oc
in reply to: kaidats
Hi @kaidats
Most likely, you have opened a structural template and are modeling an architectural wall. Or otherwise.
Also check that in visibility (VG or VV) is active wall.
Jamhmer Oc
Draw structural, not architectural walls so that you can see them in a
structyral view. Or change the view discipline to coordination so that you
can see everything.
fred2193
Try checking the visibility/graphics overrides under model categories for the view 🙂
kaidats
Now it shows.
Forma Design Contest
Technology Administrators
