working in fine mode
AhmadAAS78
Message 1 of 9
AhmadAAS78
Unable to zoom in and out or move the model in Revit after selecting Fine Detail Level.
I tried everything but still not working.
any suggestions, please?
file attached.
Replies (8)
Message 2 of 9
jay_colcombe
There definitely was an issue, I think it may have been a corrupt 3D View,
I deleted All the 3D named Views and opened a new one and did ZA and it went blank so deleted this.
Opened another 3D View Turned  ON > Show Crop Region and was able to Zoom in and out on Fine View
Also changing the Projection Node in the Properties allowed Zooming in-out in fine Mode.
Not sure 100% what solved it?
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 9
AhmadAAS78
hi Jay,
thank you for your prompt response.
I tried your steps, it zoom in and out but when i tried to rotate it... it disapear again!!
so, I delete the 3D view and make a new one, but again the same issue.
I recorded a video.
Message 4 of 9
jay_colcombe
I have to agree something is not right as even when I get Fine Detail to Work with Hidden Line it does not show correctly?
There is a lot of detail here with all the connections etc. but its not a huge model.  There is definitely something causing this!
Do you have any Visualisation Tools/Settings applied with the Graitec Add-in?
Have you tried turning off Add-ins?
Manage Tab > Extensions > Add-ins
Jay Colcombe
Message 5 of 9
jay_colcombe
I have scaled it down to the Connections, Turning OFF the Connections in your original 3D model View allows it to work without issue!
Jay Colcombe
Message 6 of 9
AhmadAAS78
yes mate, I deasabled all add ins of Revit, but still the same issue.
I open other job and its bigger than this but I dont have this problem at all.
Message 7 of 9
AhmadAAS78
yes, when turning odd the Connections it works perfectely!!
But, it should be a solution for that,no?
Message 8 of 9
jay_colcombe
It appear to be related to this Connection - Selecting it > Right Click > Select Similar (5) > Delete > All works fine
The culprits appears to be the single connection and is under another connection - Tab to select the one with the same Reference in the Type Selector in the Properties Palette
Jay Colcombe
Message 9 of 9
AhmadAAS78
thank you Jay,...problem resolved.
much Appreciated mate.
