Text Parameter
Text Parameter
martin_gallardo5D4AT
Message 1 of 10
Text Parameter
Hello guys, im doing my first steps on revit and currently im creating the symbol standard of my company and im having trouble at the moment of create a new spot elevation family.
The symbol that i need create have a text parameter that should be written by the designer for every instance and i don't know how to create that text parameter. I know that i can create a shared parameter and create a label and associate it but i don't know if create a shared parameter is the proper way bc i will have to create a lot of shared parameter for other symbols of my company.
If i add a new label only let me create shared parameters and doesn't is available the family parameter
Replies (9)
Message 2 of 10
jay_colcombe
If you need the Text Parameter to be called out in other areas of a Project such as Labels/Tags/Schedules/Etc. you need a Shared Parameter.
if you need to create your Shared Parameters that dialogue box allow you to use Select to Choose or Create a Shared Parameter to be used for that Label
Alternatively you could adopt and already defined Parameter for that Family in the list is available such as Comments
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 10
I only need the parameter for annotations and sheets.
There is no another label included in the family to be adopted.
Is it possible create a label with a family parameter?.
So the unique solution is create a shared parameter or there is another way?
Message 4 of 10
jay_colcombe
In theroty then it is shared so probable best using the original suggestion.
In a Generic Annotation you can Add a Family Parameter you could Start with a Level Head Family change the Category to Generic Annotation, Create some Family Parameter's then change back to Level Head
Jay Colcombe
Message 5 of 10
handjonathan
Hi @martin_gallardo5D4AT
Thanks a lot for posting your question to the forums!   Has the solution suggested by @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 6 of 10
I tried creating a family parameter in the "Generic Annotation" category, i added as label and then i changed it the category to "Level head" but what did happend is that the label that i created is reasigned to a family parameter of the level head category in this case (IFCGuidName).
Message 7 of 10
jay_colcombe
Can you share it for Review?
When creating the Label Family Parameter did you pick the the Correct format and group?
Jay Colcombe
Message 8 of 10
Thats how i created the parameter under the category of "Generic Annotations"
And i can add it as a label (Generic annotation category still)
But then when i switch out to "Level Family", the label that i placed under the (Generic Annotation) changes to following label
Message 9 of 10
jay_colcombe
This is standard guidance, I missed the cut to clipboard!!!  But even then i think this is still locked down for Spot Elevations!
The Tags you are using a automated so not much flexibility you really should just use Shared Parameter's where only available
How to add custom label parameters for elevation markers in Revit
Jay Colcombe
Message 10 of 10
I tried what the attached link said but didn´t work.
Finally i gave up and i had to create the shared parameter lol hahaha
Thank you so much for your help guys!
