05:02 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi!
I have this problem that when i have drawn a wall in ex. level 2. When I'm later going to make opening for windows is say:s its not cutting anything. But if I move to level 1, then i can make the cut why is that so? The same goes for doors.
Is there some kind of workaround? Or should i not use the window/door-tools for openings?
Also I have another question related to this. because of this when editing openings in level 2 it actually edits openings in level 3. When I'm standing in plan 2 even if I see level 3 I want the walls/openings to be looked.
Can uppload some materials/pics if you want to!
