Why the analytical model will not sync with the changes?
efyjw7
efyjw7
Hi, from the image you can see that although i deleted the floors at the actual model but the analytical model still display the floor. Can i know what is the reasons why the analytical model cannot sync with the actual model and how to get rid of it?
Ahmed_Muharram
check this https://youtu.be/4ClsmT-EMzY
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
hmunsell
Was the Analytical content "Associated" to the floor that was removed? If it wasn't, they are separate entities.
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-2CB7C97F-D38A-4A17-9B83-B5BE8E2C2E65
Howard Munsell
mihai.sandu
Hello @efyjw7 ,
Starting from Revit 2023 the Structural Analytical Model is separated from the Structural Physical Model. Once you select and delete the Structural Floors, this change will not propagate to the Analytical Model. You need to select the corresponding Analytical Panels inside the model and delete them too.
Mihai Sandu
Sr. QA Analyst
