Does anyone know why a structural connection applied to a column/beam will affect the previous properties of those elements? For example a structural column/beam has a certain surface pattern by material but that will disappear when connection is applied. Also, the cut line of the column in plan is changed/distorted and cut pattern no longer shown. I know this was an issue in older version like 2018 but still in 2021 version is the same? See attachments.
