why cant we model stairs in analytic mode
WALIDGIO
Message 1 of 8
WALIDGIO
hello everyone,
I'm trying to model stairs in revit analytic but i cant find a way, so i played throut by modeling it in Robot then update the model in revit to get this result, but is there a direct way to do it thank you
Replies (7)
Message 2 of 8
Ahmed_Muharram
I don't think there is another way, most of the Analytical software represent stairs with inclined slabs "based on my experience"
I think it's sufficient and you can put the weight difference as loads
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 3 of 8
WALIDGIO
hello, my question is how to model inclined slabs in analytical mode in revit, i cant do it
to get the stairs model i did model it in robot then updated my model in revit to get this result
i want to cut this work around and model the inclined slabs of stairs directly in revit, by modeling them manually in analytical mode, or model the slabs then covert them to analytical mode, but it seems impossible to do it with the actual version of revit
Message 4 of 8
catalin_lang
Hi @WALIDGIO , see the attached video with a simple example.
catalin.lang
Message 5 of 8
handjonathan
Hi @WALIDGIO
Thanks a lot for posting your question to the forums!   Has the solution suggested by @catalin_lang helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 6 of 8
WALIDGIO
According to the video, it seems that you need an existing inclined element to set a working plane aligned with it.
However, when working solely in the analytical model and trying to model stairs as inclined slabs, this becomes an issue because you can't define an inclined working plane directly.
What I'm looking for is a way to define an inclined working plane by selecting three points-similar to how it's done in Robot Structural Analysis, and then create my analytical panel on that plane.
Is there any method to do this without relying on an existing inclined element?
Message 7 of 8
mihai.sandu
Hi @WALIDGIO ,
As you mentioned, in order to create an analytical panel you need first to specify a workplane in Revit, afterwards you specify the sketch. This is the only way to create an analytical panel at the present moment in Revit.
We already received the request to create an analytical panel using 3 point definition, as you mentioned, the user select 3 points inside Revit and the analytical panel is created automatically on the workplane defined by those 3 points. This will enable users to model easily stairs and especially spiral stairs. We received this feedback in the past and is present on our development lists as a feature request.
Thank you for your feedback,
Mihai Sandu
Mihai Sandu
Sr. QA Analyst
Message 8 of 8
WALIDGIO
that's great to hear I hope they include this feature very soon
thank you
